Dual Stepper Drivers on Z axis
appswert
Re: Dual Stepper Drivers on Z axis
Post by appswert »
I'm not sure if Geeetech has removed code from the original marlin firmware...
I thaught it's caused because the original firmware simply uses an older version of marlin ;) .
appswert
Post by appswert »
Suggy wrote:Thanks appswert
Was trying to avoid going through the new Marlin firmware, Geeetech must have removed some stuff from the code. Ive built 2 printers from scratch so know the basics of setting up the configuration.h and all the other stuff that will need changing.
Thanks for explaning why it wouden't compile. Looks like I'm heading to Marlin website. That's 1/2 my evening gone lol
By the way its a Geeetech i3 Pro b with the 3d touch (pain in the ass to setup).
May put an inductive one on my self build when I upgrade it to E3D
Thanks for the help much appreciated
You mentioned that you want to upgrade to e3d... I bought an e3d clone from ebay (which arrived already). Do you already found a sensor mount?
Because I found two on thingiverse which dont't include a new x-carriage which I like.
https://www.thingiverse.com/thing:2170993
https://www.thingiverse.com/thing:2025441
Do you have found a better option? Are you going with bowden or direct drive?
Suggy
Post by Suggy »
Thanks for the heads up but the one they will be going on is a bizer slyle printer
It as got a bigger HBP since I took this photo
300x200mm
Ubedt
Post by Ubedt »
Thank you for the information
