Software always cause troubles.
lotonegro
Re: Software always cause troubles.
Post by lotonegro »
Well. I've changed the bauds. Then it worked. So the first thing I have doing is to say. Thanks for your help. I did a small cilinder. Next thing I would like to ask you is about printing. So I've made two other proves but they faulled. Because the first layer is dropped and dragged produce a extrange mass. Tell me something about it or send me to another conversation.
You need to level your bed at first
If the distance of nozzle and the heat bed not suitable
Then you will get the bad result
aps.dauerpraeparate@bluewin.ch
Post by aps.dauerpraeparate@bluewin.ch »
Hi, I have the same problems with Geeetech 301 and I can not calibrate the printer ..........?
mikil
Post by mikil »
good morning, first of all congratulate them for the forum, it is very educational and to speak for my english that is quite bad, I admit it. I am new to the forum and I would like to see if you can help me, the fact is that a few weeks ago I bought your i3 geeetech and I found the axis and from time to time I took steps, I changed the firmware a lot of times and with different versions, I have fretted with the machine (adjusting the belt, changing the motor, adjusting the amperage, checking that it does not collide, changing the unit A4988) I do not know what else to look, if you can give me a hand I would appreciate it.
Thank you.
