Downside to running fans from a buck converter? 24V Upgrade
avensiis
Re: Downside to running fans from a buck converter? 24V Upgrade
Post by avensiis »
Thanks for the suggestions !
192.168.100.1 192.168.1.1
mattjames1980
Post by mattjames1980 »
wanna do this the other way with my A30M to get some Noctua fans, anyone tried running 12V fans off a 24V psu? looking at buck converters as well
Blanca21
Post by Blanca21 »
Issue with replacing 24v fan with 12v fan using buck converter
I really want to reduce the noise from the hot end fan so I bought a noctua fan and a buck converter from amazon. I was following a couple of guides for how to do this but none of them mention (and I didn't think about) the fact that buck converters not only reduce the voltage (good) but also increase the current by a corresponding amount. This will take the current over the specified max current and blow the fan. So, do I need to find a buck converter with a limited/adjustable output current as well as adjustable voltage? Or am I doing something wrong?
My Lowes Life
Perry1148
Post by Perry1148 »
Thanks for sharing, I found a lot of interesting information here. A really good post, very thankful and helpful that you will write many more posts like this one. indigocard
Walters6697
Post by Walters6697 »
This works really well for me, thank you! Facing same issue here. Help is appreciated. MyBalanceNow
Battin658
Post by Battin658 »
You can still use a single buck converter to run the fans individually. To this end, simply feed the input of the buck converter with 24V.
rapidfs
Laurens
Post by Laurens »
you might lose RPM control on the part fan?
Movierulz4 free movies
deanalee
Post by deanalee »
I installed my buck converters, after setting them up on a 24v power supply.
Connected up the control box fans with the converters.
I then installed my new 24v PSU.
Turned the control box on and the noise was really deafening!
It sounded like my vacuum cleaner was on the table next to me.
My control box was really vibrating which exacerbated the noise.
I had set my buck converters to 12v. Could I have had 6v fans? lol
I shall strip it down again tomorrow and retest the converters.
sigma1
Post by sigma1 »
each time i heard how tons disappointment the king will be, it changed into like a river of
vehicle inspection near me
