Page 2 of 2
Re: Downside to running fans from a buck converter? 24V Upgrade
Posted: Tue May 26, 2020 12:20 pm
by avensiis
Thanks for the suggestions !
192.168.100.1 192.168.1.1
Posted: Mon Jun 15, 2020 9:48 pm
by mattjames1980
wanna do this the other way with my A30M to get some Noctua fans, anyone tried running 12V fans off a 24V psu? looking at buck converters as well
Posted: Tue Jul 27, 2021 1:24 pm
by Blanca21
Issue with replacing 24v fan with 12v fan using buck converter
I really want to reduce the noise from the hot end fan so I bought a noctua fan and a buck converter from amazon. I was following a couple of guides for how to do this but none of them mention (and I didn't think about) the fact that buck converters not only reduce the voltage (good) but also increase the current by a corresponding amount. This will take the current over the specified max current and blow the fan. So, do I need to find a buck converter with a limited/adjustable output current as well as adjustable voltage? Or am I doing something wrong?
My Lowes Life
Posted: Mon Aug 30, 2021 5:38 pm
by Perry1148
Thanks for sharing, I found a lot of interesting information here. A really good post, very thankful and helpful that you will write many more posts like this one.
indigocard
Posted: Fri Sep 03, 2021 1:33 pm
by Walters6697
This works really well for me, thank you! Facing same issue here. Help is appreciated.
MyBalanceNow
Posted: Wed Sep 08, 2021 5:42 pm
by Battin658
You can still use a single buck converter to run the fans individually. To this end, simply feed the input of the buck converter with 24V.
rapidfs
Posted: Tue Oct 12, 2021 5:07 pm
by Laurens
you might lose RPM control on the part fan?
Movierulz4 free movies
Posted: Fri Jan 07, 2022 1:14 am
by deanalee
I installed my buck converters, after setting them up on a 24v power supply.
Connected up the control box fans with the converters.
I then installed my new 24v PSU.
Turned the control box on and the noise was really deafening!
It sounded like my vacuum cleaner was on the table next to me.
My control box was really vibrating which exacerbated the noise.
I had set my buck converters to 12v. Could I have had 6v fans? lol
I shall strip it down again tomorrow and retest the converters.
Posted: Thu Jun 30, 2022 10:44 am
by sigma1
each time i heard how tons disappointment the king will be, it changed into like a river of
vehicle inspection near me
