Using the right feed
wkdmarty
Re: Using the right feed
Post by wkdmarty »
I think I get it. I'll have a play around and see what spits out.
My original question was about how to print different models using the different spools, then when I got that to seem to work, the TPU (right hand spool) wasn't coming out the extruder but the correct feeder was turning. So I guess the question did evolve. My apologies.
Thanks you all so much for your time and input.
Is there a Linux slicer that does do spool mixing on the A10M?
It's hugely appreciated.
Marty
wkdmarty wrote: Tue Mar 26, 2019 4:48 pm I think I get it. I'll have a play around and see what spits out.
Marty
You can try to use the Cura for it(The Cura has the version for the Linux)
Then you need to add the plugin for A10M:
https://www.thingiverse.com/thing:3442615
cheers
