Page 2 of 2
Re: Printer heating bed switches off
Posted: Tue Apr 09, 2019 1:11 am
by Hajo
ok, here is a photo.
Now I will contact Geeetech for a replacement PSU. So I hope for goodwill, because the printer is only half a year old!
Posted: Tue Apr 09, 2019 1:55 am
by _kaktus_
Well, well...
One resistor
(R23) has no leg
I cared more about the outer photo. Especially in a place with a label. To see what it is.
Posted: Wed Apr 10, 2019 8:07 pm
by Hajo
that's right, R23 only has one leg left. Also R28 is broken. For the white material on the electrolytic capacitors, I first thought that one of the capacitors had burst, but it is probably an elastic adhesive. But during the desoldering, I noticed that there is a cold solder joint on a connecting leg (both capacitors are ok.).
Here is a picture of the type of PSU.
Posted: Thu Apr 11, 2019 12:59 pm
by _kaktus_
Hi.
Thank you.
Now we all know what to avoid.
This is a budget version, which is worth avoiding with a wide arc
Yeah, it's white. It's glue. Its purpose is to absorb mechanical stress, and it will keep large elements in place. In this way, the leads will not be torn out of the component and PCB.
Posted: Thu Apr 11, 2019 2:10 pm
Your printer is the old version and it uses the 12V version PSU.
The new version PSU is the 24V type.
We suggest you upgrade it to 24V PSU as soon.
You can find it at:
viewtopic.php?f=92&t=61498
Posted: Sun Apr 14, 2019 5:23 pm
by Hajo
I would like to do the upgrade to 24V, but I can not find the required spare parts (except the PSU), neither under the name nor under the specified order number. Is there a complete upgrade kit?
Posted: Wed Apr 17, 2019 8:31 pm
You can contact the sales at first.
Then ask them the 24V upgrade kit for A30.
They will give you more help.
Posted: Wed Apr 24, 2019 11:39 pm
by Hajo
and it was: the heating bed!
after I installed a new PSU the message came again and again after a short time:
Error Nozzle-0-Temp, the printing job has stopped.
When I replaced the temperature sensor and the heating cartridge one after the other - no change.
Luckily, yesterday came a new heatingbed from Geeetech - switched to 12V, installed - and everything works well again!
Posted: Fri Apr 26, 2019 3:59 am
by _kaktus_
Hi.
It was a nasty malfunction. But you did well, and that's why I'm happy about it.
