New M201 LCD Problems
cwolfe
Re: New M201 LCD Problems
Post by cwolfe »
I posted the pictures in portrait not landscape when posted they are being forced into landscape probally due to size, and yes i have a multimeter.
It's good not to take pictures of your computer screen. Do you know the functionality of the Print Screen key :?:
I'll have a description of the next test in a moment.
:idea:
I would like to ask you to test all connections to the display module with your circuit continuity tester.
But in a specific way.
Conect the controller with the display module using the FFC cable. Disconnect all other wires from the controller.
Test the leads I pointed out with a pen in the picture. The circuit diagram will be very helpful.
cwolfe
Post by cwolfe »
There is no continuity at those points.
by the way thankyou for all the help.
Hi.
:mrgreen:
Then you have diagnosed the fault and it is very easy to fix.
I think there are cold soldering somewhere.
All you have to do is to improve the soldering points and everything will work like new. :D
If you have any more problems, feel free to ask.
