Page 2 of 2
Re: A10M MARLIN 2.0 BLTOUCH NOT WORKING
Posted: Tue Feb 04, 2020 5:32 pm
by vap38
thank you !
alas I do not find in example the configuration.h for the geeetech a10m bltouch?
a +
Posted: Wed Feb 05, 2020 8:55 pm
by vap38
I spent at least more than 2 hours modifying the define options with // the configuration.h works with bltouch but there are somea bugs.
The mixing on the menu does not appear on the a10m printer.
I have the Mixing option validated in config.h.
There are many options that are quite complex. I do not master everything it would take a tutorial to understand everything.
Again thank you for your help, I will try to understand everything with your help.
conclusion it is a lot of work to have a very clean config.h file!
I understand why now few people are able to correct the file.
you must clean up the config.h file because otherwise it is too large with Arduino!
a +
Posted: Mon Feb 10, 2020 2:01 pm
by Din0
does anyone have a functional FW Marlin 2.0x for A10M+Bltouch?
Posted: Tue Feb 11, 2020 2:32 am
by Din0
thank you for fw I uploaded version 2.1 for A10M and works. I would like to ask you if you would send me for A10M +BLtouch modified "Configuration.h and Configuration_adv.h " I would like to exchange drivers for X and Y for TMC2208 without UART and also the language cz. I've done basic things, but version 2.x looks more complicated.
Thank you Ales
Posted: Tue Feb 11, 2020 10:18 pm
by gdroos68
Din0 wrote: Mon Feb 10, 2020 2:01 pm
And with an GT2560 V4.0 board?
Posted: Fri Feb 14, 2020 3:49 am
by Din0
Hi VERT,
I modified the file " Start_here.h " according to my configuration and looks to work well tested version 2.1.
When replacing filament, however, only extruder E1 comes out and I do not know how to replace Filament in extruder E0 using the menu. Is this somehow resolved in your version? I'm trying the Marlin 2.1 version.
Thank you for your support Ales
Posted: Mon Feb 17, 2020 9:16 pm
by vap38
I am surprised that VERT always gives the solution (go towards !!!!!
Check out my Marlin 2.0 fork for Geeetech 3DPrinters). it's not very easy to get the right files and the right configuration. For my part I am disappointed because the configuration.h and adv files are not simply deposited in a folder?
For my part, I spent hours modifying the Configuration.h file by putting // everywhere.
it would be easier to put a download link in example A10M and A20M with the BLtouch which works well and tested ...
I am not convinced that version 2.0 of Vert brings anything positive on the operation of the printer.
My version 1.18 works very well
So do something more constructive and functional for everyone to share. Thanks for them!
