DId you see my profile for slic3r? There are Z-hop 0.1mm. Extruder hot tip is not for technical "right-angled" things, but for sculptures.
And your retract is missing...
Mixing hot end issues and cura
Re: Mixing hot end issues and cura
A10 Slic3r profile: here
I'm testing my new A20M and have issues with mixing and extruder 2
The test File with the dog, provided by Geeetech, printed perfectly.
I am using Cura 4.4.1
I followed this whole post and the youtube video to adjust my settings for extruders 1 & 2.
Here my settings in Cura :
- Printer - Extruder 1 - Extruder 2 When printing a Gcode, only with extruder 1, the print is fine (need to be improved, but fine for the moment))
When printing a Gcode, only with extruder 2, or a dual print using extruder 2 (e.g. the traffic cone) the print stop with the message : : TEMP TOO LOW! It seems that at this moment the Extruder 2 is at the setpoint 150°C, which is the Stand-by Temperature in Cura.
I'm gonna try to change it to 200°C on the 2 extruders, but is it the good solution?
Thanks for your help
Christophe
Christophe
Answer to myself :
Yes, that's it. I have to increase the "Stand By Temperature".
But my first Dual printing is still far away from 'perfection'...
Work in progress
Christophe
Answer to myself :
Work in progress
Christophe
You can view your print temperature settings.
hola me podría explicar como as cambiado en cura los parámetros de la temperatura por favor tengo el mismo problema que tu gracias un saludochc wrote: Tue Dec 31, 2019 11:47 pm Hello,
Answer to myself :
Work in progress
Christophe
