Re: GTM32 Rev B Board Schematic?
Posted: Sat Jun 13, 2020 8:40 pm
Hi _kaktus_ I have to agree with colcolo... this schematic is not readable
Any chance you could get readable (higher resolution) version, maybe even original PDF...
I have finally managed to flash my GTM32 Rev B using ST-Link, now I just need correct pinouts to make it run properly!
EDIT: I have had some success with reverse-engineering the pinout...
See attached picture... looks like some adjustments are still necessary
EDIT: I have figured out proper pins now:
Code: Select all
#define LCD_PINS_RS PA13 // CS chip select /SS chip slave select
#define LCD_PINS_ENABLE PC7 // SID (MOSI)
#define LCD_PINS_D4 PD1 // SCK (CLK) clock
#define LCD_PINS_D5 PD4
#define LCD_PINS_D6 PD5
#define LCD_PINS_D7 PD7
Code: Select all
#define LCD_PINS_RS PA12 // CS chip select /SS chip slave select
// RW is hardwired to VSS
