Patching A20T firmware for 3dTouch
Re: Patching A20T firmware for 3dTouch
I'm also in exactly the same situation - there is also another thread with someone else having this issue. Clearly there is an issue that needs to be sorted by Geetech!
Hi,When you use the Firmware Toolkit to update the firmware,
While uploading the firmware, press and hold the reset button of the printer,
Upload.
Upload.
No, still not working. It still gives the same result as this viewtopic.php?f=117&t=69693
i updated yesterday the firmware with the toolkit because i put a 3d touch on it and is now working i used a usb3 connection on my computer.
Grt André
Grt André
Last edited by andrevanderweide on Wed Dec 11, 2019 11:50 pm, edited 1 time in total.
Creality Ender 3v2
Creality S10 Pro Marlin 2.0
When we try to use the firmware uploaded it won’t it forever times out. Some other searching revealed that the perhaps the board doesn’t have a boot loader installed and that’s why no one can patch the firmware. I’m traveling at the moment, But I’m going to try and install a boot loader and then try and patch it. I’ll document the process if I’m successful and share it with everyone @Erica
Can you describe what you did? (did you hold reset as they suggest, did you have to install a bootloader) ...andrevanderweide wrote: Mon Dec 09, 2019 11:42 pm i updated yesterday the firmware with the toolkit because i put a 3d touch on it and is now working i used a usb3 connection on my computer.
Grt André
Can you describe that in a bit more detail william? At which point do you release the reset button, AFTER you've pressed "Upgrade from Local"?William wrote: Mon Dec 09, 2019 6:12 pm Hi,When you use the Firmware Toolkit to update the firmware,
Upload.
I'm pretty sure the issue with my printer is that there isn't a bootloader on the board. which is why AVRDude times out constantly. I've seen some videos on how to install a bootloader with a Arduino Uno... @William or someone from Geeetech can we get instructions on how to install a bootloader on this board?
I did not have to install bootloader ia started the toolkit load the new file local and started the upload and then pres the reset short and it started.lmcmulle wrote: Sat Dec 14, 2019 11:06 pmCan you describe what you did? (did you hold reset as they suggest, did you have to install a bootloader) ...andrevanderweide wrote: Mon Dec 09, 2019 11:42 pm i updated yesterday the firmware with the toolkit because i put a 3d touch on it and is now working i used a usb3 connection on my computer.
Grt André
today i leveld the bed and started the first mix color print
Creality Ender 3v2
Thanks man, seems like you got lucky and got a bootloader on yours, Mine is getting returned to amazon monday if I don't get any advice on how to fix this --- sad too as this printer has so much potential.
