Z axis problem
Re: Z axis problem
Hi, can you use screen to move the zaxis?
such as 10 or more?
and change the model to slicr.
novawaves
Re: Z axis problem
Post by novawaves »
hi,
now i have a new info. yesterday i notice that the 4 screw on the left threaded rod is loose. so i tighten the screws and the rod will move much harder, when i loosen it the rod will move light. than i saw that the rod is a litte bit bent. do you think this could be my problem? where did i get a new rod?
thx
Re: Z axis problem
Hi, are the four screws on the brass screws,
Does it play a fixed role?
You can see if the threaded rod is bent,
If you bend, you can contact your sales description.
novawaves
Re: Z axis problem
Post by novawaves »
hi could you please give me the standard definition which i have to input in control motion menu
please tell me all the constants which are standard in these menu
thx
novawaves
Re: Z axis problem
Post by novawaves »
now i have make a big progress
i have changed the steps / mm for the z axis to 2600 and the extruder moves approximately 10mm when i use the manual controll
so i think i have changed the steps/mm for my i3x with a gcode that i have used.
when i reflash the firmware the steps/mm are 400 so there is a big difference
why is this so and what are the correct factory defaults?
please give me all the factory constants
thx
Re: Z axis problem
Hi, you can refer to this: viewtopic.php?f=66&t=69776
novawaves
Re: Z axis problem
Post by novawaves »
thank you thats the solution, the firmware i updated have 400 steps/mm and i have the left rod wich neets more steps!
Re: Z axis problem
novawaves wrote: Wed Apr 01, 2020 1:43 pm thank you thats the solution, the firmware i updated have 400 steps/mm and i have the left rod wich neets more steps!
:D
topcar
Re: Z axis problem
Post by topcar »
The 2022 Jeep Grand Cherokee hpr comes standard with a 6.4-liter V8 SRT engine that develops 475 horsepower and 470 pounds. from the torque. https://www.gtopcars.com/makers/jeep/20 ... -cherokee/
imtopautomag
Re: Z axis problem
Post by imtopautomag »
The best and top rating SUVs, auto magazines, coupes, Scooters, Motorcycles, wagons, convertibles, minivans, hybrids, and future bikes model collection with photos.https://www.instapaper.com/p/topautomag
