It is not easy to get the BL (or 3D) touch up and working. But it works fine and prints very well. It is not perfect and needs tweaking now and then but much less than manual bed leveling and using the stock Z stop.
If you have a Pro B then use sample Pro B file.
I agree that Geeetech should do a better job of helping. I asked for sample Pro A files and was ignored. Finally I used the Pro B file with suitable modifications.
Posting again to see if anyone has any suggestions as I am stumped.
I've checked the wiring and I know it to be good.
All commands work.
To put it simply, when I go to home the printer the pin goes down then goes back up as if it was detecting the print bed even though it didn't. The polarity is correct on my endstop wiring.
I got a replacement sensor assuming that was the issue but it's still having the same problem. "
I made a video.
Does anyone know any solutions to this issue? I used the FW file in the first post so I know the code is correct, unless something else needs to be changed there.
All commands work.
I made a video.
Have you edited pins.h?
Yes, I used the FW zip in the first folder which includes the changes to pins.hcosmith wrote:Have you edited pins.h?
I am using the GT2560 board for my printer. Could this possibly be part of the issue with the FW in the first post?
I wouldn't think so. I think those firmwares are for the GT2560 specifically. You could always try modifying the stock firmware instead.
Older version of Marlin firmware are bugged and autoleveling don't work.
I've downloaded last RC (v 1.1.0 RC8) from github, made some changes in "configuration.h" and in "pins_ULTIMAKER.h", compiled and uploaded.
Changes to made in configuration.h
Please note that I've the E3D Hotend, CHANGE IT if you have the Geeetech original
Search Thomas Sanladerer PID tuning video
Changes to made in pins_ULTIMAKER.h
Code: Select all
// The following define selects which electronics board you have.
// Please choose the name from boards.h that matches your setup
#ifndef MOTHERBOARD
#define MOTHERBOARD 7
#endif
Code: Select all
* Select your power supply here. Use 0 if you haven't connected the PS_ON_PIN
* 0 = No Power Switch
* 1 = ATX
* 2 = X-Box 360 203Watts (the blue wire connected to PS_ON and the red wire to VCC)
* :{ 0:'No power switch', 1:'ATX', 2:'X-Box 360' }
#define POWER_SUPPLY 1
Code: Select all
// original definition by GEEETECH
// -->> #define TEMP_SENSOR_0 1 <<--
// DEFINE PER E3D V6 HOTEND AS IN WEB PAGE http://wiki.e3d-online.com/wiki/E3D-v6_Assembly
// 5
#define TEMP_SENSOR_0 5
Code: Select all
//============================= PID Settings ================================
// DEFAULT PER GEEETECH
#define DEFAULT_Kp 22.2
#define DEFAULT_Ki 1.08
#define DEFAULT_Kd 114
Code: Select all
//============================== Movement Settings ============================
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,400,93} // default steps per unit for Ultimaker
#define DEFAULT_MAX_ACCELERATION {3000,3000,20,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 1000 // X, Y, Z and E acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 1000 // E acceleration in mm/s^2 for retracts
#define DEFAULT_TRAVEL_ACCELERATION 1000 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves
Code: Select all
//============================= Z Probe Options =============================
// The BLTouch probe emulates a servo probe.
// The default connector is SERVO 0. Set Z_ENDSTOP_SERVO_NR below to override.
#define BLTOUCH
// Z Servo Probe, such as an endstop switch on a rotating arm.
//#define Z_ENDSTOP_SERVO_NR 0
//#define Z_SERVO_ANGLES {70,0} // Z Servo Deploy and Stow angles
#define Z_SERVO_ANGLES {10,90} // Z Servo Deploy and Stow angles
// *USE YOUR VALUES*
// modificato da Sergio il 25/02/17
#define X_PROBE_OFFSET_FROM_EXTRUDER -2 // Probe on: -left +right
#define Y_PROBE_OFFSET_FROM_EXTRUDER -20 // Probe on: -front +behind
#define Z_PROBE_OFFSET_FROM_EXTRUDER -2 // -below (always!)
// X and Y axis travel speed (mm/m) between probes
// #define XY_PROBE_SPEED 8000
#define XY_PROBE_SPEED 1000
// Enable Z Probe Repeatability test to see how accurate your probe is
#define Z_MIN_PROBE_REPEATABILITY_TEST
// #define Z_CLEARANCE_DEPLOY_PROBE 10 // Z Clearance for Deploy/Stow
#define Z_CLEARANCE_DEPLOY_PROBE 5 // Z Clearance for Deploy/Stow
#define Z_CLEARANCE_BETWEEN_PROBES 5 // Z Clearance between probe points
Code: Select all
// @section machine
// Travel limits after homing (units are in mm)
// #define X_MIN_POS 0
// #define Y_MIN_POS 0
// #define Z_MIN_POS 0
// #define X_MAX_POS 200
// #define Y_MAX_POS 200
// #define Z_MAX_POS 200
// MY SETTINGS
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define X_MAX_POS 195
Code: Select all
//#define AUTO_BED_LEVELING_3POINT
//#define AUTO_BED_LEVELING_LINEAR
//#define AUTO_BED_LEVELING_BILINEAR
// Set the boundaries for probing (where the probe can reach).
// #define LEFT_PROBE_BED_POSITION 15
// #define RIGHT_PROBE_BED_POSITION 170
// #define FRONT_PROBE_BED_POSITION 20
// #define BACK_PROBE_BED_POSITION 170
#define LEFT_PROBE_BED_POSITION 30 // 15
#define RIGHT_PROBE_BED_POSITION 180
#define FRONT_PROBE_BED_POSITION 40
#define BACK_PROBE_BED_POSITION 180
Code: Select all
// - Allow Z homing only after X and Y homing AND stepper drivers still enabled.
// - If stepper drivers time out, it will need X and Y homing again before Z homing.
// - Move the Z probe (or nozzle) to a defined XY point before Z Homing when homing all axes (G28).
// - Prevent Z homing when the Z probe is outside bed area.
#define Z_SAFE_HOMING
Code: Select all
// EEPROM
// The microcontroller can store settings in the EEPROM, e.g. max velocity...
// M500 - stores parameters in EEPROM
// M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily).
// M502 - reverts to the default "factory settings". You still need to store them in EEPROM afterwards if you want to.
//define this to enable EEPROM support
#define EEPROM_SETTINGS
Code: Select all
// SD CARD
// SD Card support is disabled by default. If your controller has an SD slot,
// you must uncomment the following option or it won't work.
//*MOD*
#define SDSUPPORT
Code: Select all
// Number of servos
// If you select a configuration below, this will receive a default value and does not need to be set manually
// set it manually if you have more servos than extruders and wish to manually control some
// leaving it undefined or defining as 0 will disable the servo subsystem
// If unsure, leave commented / disabled
//#define NUM_SERVOS 3 // Servo index starts with 0 for M280 command
#define NUM_SERVOS 1
Code: Select all
// Servos
// #define SERVO0_PIN 13 // untested
#define SERVO0_PIN 32 // 12
// Limit Switches
#define X_MIN_PIN 22
#define X_MAX_PIN 24
#define Y_MIN_PIN 26
#define Y_MAX_PIN 28
#define Z_MIN_PIN 30
// #define Z_MAX_PIN 32
#define Z_MAX_PIN -1
Originally I started off with modding my firmware then switched over to the one here when I had issues.cosmith wrote:I wouldn't think so. I think those firmwares are for the GT2560 specifically. You could always try modifying the stock firmware instead.
I'll see about updating and using the BLTOUCH method.
So I used the marlin package Marlin-1.1.0-RC7 for PI3 Pro B7and made a couple changes based on the code listed above by menestrello (thank you again).
It's basically doing the exact same thing which leads me to believe something is going on at a hardware level. It's just strange that my mechanical endstops work fine. I also had inductive sensors before and those worked as well.
Anyone know if there any kind or tests and/or readings I can do to figure out the source of the issue?
I saw your video. What commands are you giving the printer to do what it did in the video?
