Just G28 to homedaveapplemotors wrote:I saw your video. What commands are you giving the printer to do what it did in the video?
halo friends
i bought also the auto leveling sensor but i think i can not be in a condition to change the firmware
so my question is .....can you find for me a "sensor ready " firmware to upload and do my job ?
thank you very much
Regards
thank you very much
Regards
If you have a Geeetech Prusa i3A I can send you my "Sensor ready firmware". But you must make a mount for your BL touch that is the same as mine becasue of the Z offset--X and Y .
And Xalu:
I issue:
M280 P0 S160 ; BL touch alarm off
G28 X0 Y0 ;to get a reference for X and Y
G28 Z0 ;Z goes to a stored value
M280 P0 S10 ; extend the BL touch pin
G1 Z6 ; to clear the pin when the carriage moves to the center
G28 ; now it goes to the center
G29 ; this must follow G28 immediately
Those commands are in the startup file to be added to the first part of each G-code.
I issue:
My noozzel hot end point and 3d touch sensor point is same level.So when noozel prints sensor will remove.How to fix this please anybody letme know.
Thanks advance
<blockquote class="imgur-embed-pub" lang="en" data-id="a/KHtxG"><a href="//imgur.com/KHtxG"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
Shiva
Thanks advance
Shiva
Mechanically adjust sensor height. Make another bracket if you can not do this.
I ran these commands one at a time and got an error on G28.daveapplemotors wrote:And Xalu:
I issue:
15:10:08.856 : M280 P0 S160
15:10:25.915 : G28 X0 Y0
15:10:31.749 : X:0.00 Y:0.00 Z:7.60 E:0.00 Count X: 0 Y:0 Z:19418
15:10:43.580 : G28 Z0
15:10:58.214 : X:100.00 Y:103.00 Z:7.60 E:0.00 Count X: 9099 Y:4132 Z:19418
15:11:00.299 : M280 P0 S10
15:11:09.796 : G1 Z6
15:11:20.116 : G28
15:11:35.459 : Error:Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
15:11:35.459 : X:100.00 Y:103.00 Z:7.60 E:0.00 Count X: 9099 Y:4132 Z:19418
Update: I switched to mechanical endstop to verify the firmware is working with endstop and it works fine with mechanical. I am getting a new error message though "15:40:45.708 : echo:G28 Z Forbidden"
Well apparently there are a few different models out there. This one is triangle lab and that was the problem. You need set "Z_MIN_ENDSTOP_INVERTING true". Found instructions here https://drive.google.com/file/d/0B_lX6B ... hSems/view incase anyone has similar issue.
Now I can finally test it properly. Thanks for all the help everyone
I have also installed the 3D touch and the function is great but unfortunately I can not print because the nozzle is about 2mm too high over the bed.
I have gone to the tutorial to adjust the printer but somehow it does not go. The display also shows me always endstop hit: Z.
When retrieving the command M851 comes synonymous always 0.00 no matter how I set Z. The command to write to Eeprom I have also changed. G28 goes also and with G29 the nozzle is already set too high. I tried with #define Z_PROBE_OFFSET_FROM_EXTRUDER -1.2 or -1.9 or -2.1 but after the use of the command M851 still 0.00 is displayed. Of course always with the M500 stored. Printer are the i3 Pro B and I use Simplify 3D as software.
Can someone help?
Bernd
Can someone help?
Bernd
Bernd,
#define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS.
Try changing the above to false. When the above is set to true it won't allow the z axis to go negative.
I just wanted to give an update. I have tried reverting back to the older firmware with the settings for invert and the probing wouldn't work.
How I got everything working:
So the best method is to update to the latest firmware when using the touch sensor. I've ran numerous tests and the new firmware (Marlin-1.1.0-RC7 for PI3 Pro B) along with the changes menestrello posted. This set up seems to be working very well.
Thank you to everyone for the help
