EndStops problem
zhangxueyou
Re: EndStops problem
Post by zhangxueyou »
Are this 2 LEDs lit when you turn on the printer?
And please check the microstep of y motor: If you are using A4988, the number of jumper cap under A4988 should be 3.
mallensp
Post by mallensp »
no only one led is on.
mallensp
Post by mallensp »
Under each A4988 are 3 Junpers set.
mallensp
Post by mallensp »
as you can see in the picture, there is only one led on.
And i checked the microstep setting too: there are 3 jumper
under each A4988.
zhangxueyou
mallensp wrote:Hi,
under each A4988.
Over high currect caused 10A fuse burnt, you need to replace a new fuse.
mallensp
Post by mallensp »
do you have any idea, how the fuse is gone?? Remember, the printer was only in stand-by, without any motion and the extruder and the bed where off too.
And could you post me the correct reference of this fuse.
thank you
zhangxueyou
mallensp wrote:Hi,
thank you
Some where is short circuit, so the fuse is gone.
The reference of the fuse is 10A/125V.
mallensp
Post by mallensp »
hi,
today i received an order of littlefuse.
i spend 3 fuses to identify the faulty part. :-) The A4988 of the x-axis caused the short!
i replaced it temporary with the A4988 of extruder 2 and i printed my first calibration object
without any further problems.
