For people who wants STL files of parts
Re: For people who wants STL files of parts
Thank you for the attention and fast response, Eric.
I purchased your dual extruder and am installing it on a Prusa i3 printer. The dual extruder holder stl file does not fit the dual extruder I purchased. You have no heatsinks and one fan on the extruder provided with your pro c printer kit but the dual extruder you sell separately has 2 heatsinks and two fans so it won't fit the holder. Is it ok to install without the heatsinks? Why 2 different versions of the same thing? No stl file for a holder that will fit mine?
Are the printed parts (stl files) for the Prusa i3 pro C the same as the i3 B? I realize the dual extruder mount is already listed separately, but I do not see a listing for the other i3 C parts. If they are not the same could you please post them or send them in an email?
On another note, this thread is not the easiest thing to find and does not appear when searching the forums for "stl". Perhaps you could put a link to this thread in the build instructions or on the webpage for each of these printers. A better solution would be to add a "downloads" section to your main page or to each printer's webpage; in this section you could provide stl files as well as firmware files saving everyone a great deal of time.
the3dstudent@gmail.com
hi,could you take a picture of you new dual extruder and heat sink?leo wrote:I purchased your dual extruder and am installing it on a Prusa i3 printer. The dual extruder holder stl file does not fit the dual extruder I purchased. You have no heatsinks and one fan on the extruder provided with your pro c printer kit but the dual extruder you sell separately has 2 heatsinks and two fans so it won't fit the holder. Is it ok to install without the heatsinks? Why 2 different versions of the same thing? No stl file for a holder that will fit mine?
hi,these stl files are the same,could you please take a picture of "mount" and "thread" in the review.i'm not sure whict part you describe.thx.
"Thread" == forum topic/question and all associated replies
Which stl files are for the Prusa i3 pro C with dual mk8 extruders(see link below)?
http://www.geeetech.com/unassembledgeee ... p-927.html
Are the i3x .STL parts availabe?
I3 X have no printed plastic parts so there's no stl files for it.
Which if any of the above be for an 8mm Acrylic i3 Pro B and C?
tia
tia
Hi,chase wrote:Hi,
tia
What your "8mm" means?
