Dual extruder sagging: anyone else
x306xcptnkirk
Re: Dual extruder sagging: anyone else
What is the best way to get abs to stick to the print bed? What settings should be used?
zhangxueyou
You can smear a layer of glue to make the filament stick to bed. To print with an extruder, you can refer to this page to set slicer:x306xcptnkirk wrote:What is the best way to get abs to stick to the print bed? What settings should be used?
http://www.geeetech.com/forum/viewtopic ... 24&t=16366
x306xcptnkirk
Heat bed is at 95, extruder at 240 and elmers glue and it is still peeling up on the corners. What is the best glue to use?
zhangxueyou
It'd better like this one: http://es.aliexpress.com/store/product/ ... 61306.htmlx306xcptnkirk wrote:Heat bed is at 95, extruder at 240 and elmers glue and it is still peeling up on the corners. What is the best glue to use?
You can also use common liquid glue but it's harder to get the item out of bed after printing.
