Z home with autolevel
qdshombre
Re: Z home with autolevel
Post by qdshombre »
05:19:39.587 : x_min: TRIGGERED
05:19:39.587 : y_min: TRIGGERED
05:19:39.587 : z_min: open
Don't match for Z. It's my problem since the beginning...(3 weeks on Tuesday)
William Kwok wrote: If you did,check the connection between the endstop and the endstop's connector on the motherboard.
the sensor receives 9 v . the sensor signal is sent to the Z min signal with 4.5 V and ground is connected to ground of the power supply.
i3 Pro C double extrudeur MK8 - carte GT2560 avec 5 A4988 - lit chauffant
qdshombre wrote:05:19:39.587 : x_min: TRIGGERED
What is this?"the sensor receives 9 v . the sensor signal is sent to the Z min signal with 4.5 V and ground is connected to ground of the power supply."
And what you mean "don't match",was it a wrong one?
And did you have a wrong connection to plug the Z endstop into the Z_MAX connector?Or you have a broken Z endstop...Have you done this i told you before?Look the following pic:
If possible,attach a video about all your manipulate in details.
qdshombre
Post by qdshombre »
schema (Copier).jpg (25.83 KiB) Viewed 11757 times
I have X home and Y home, not Z home.
I have nothing in Z max. The light sensor turns on but Z don't stop .
attachment , the schematic of connection.
20160604_212547 (Copier).jpg (113.95 KiB) Viewed 11757 times
You mean the Z_min circuit has a problem?And what is the light sensor?Post a pic of your Z axis after you press "home" plz.
qdshombre
Post by qdshombre »
I say for two weeks home Z does not work, the light of the sensor turns on but the extruder does not stop and continues to go down, and I have to stop . it is an NPN NO sensor .
qdshombre
Post by qdshombre »
there is a technician to help me out? I will not advise Geeetech... 22 days I'm at stop and no one to help me ...
qdshombre wrote:I say for two weeks home Z does not work, the light of the sensor turns on but the extruder does not stop and continues to go down, and I have to stop . it is an NPN NO sensor .
Two question:
1.Have you tried to exchange the Z axis its own endstop with another endstop?(Like X axis or Y axis,cuz they are good ones)
Like i said before,but you didn't reply to me if you have done this step.This step is to check if your Z axis endstop was broken:
qdshombre wrote:"That is to say,as you know there are 3 endstops in total(X axis,Y axis and Z axis).I mean you can uninstall the endstop installed the X axis or Y axis before,then install the uninstalled endstop to Z axis's position cuz you said the X and Y axis can home normally."
2.I saw you plugged the 2 Y cables on Z_min,and Y axis don't stop...
On the other hand,i want to ask you,did you have a try to plug the 2 Z cables on X_min or Y_min to see whether Z axis will stop or not????
qdshombre
Post by qdshombre »
I do not understand how. if I remove the endstop Y for example , the motor blocks, I must stop and I cannot try Z.
qdshombre wrote:I do not understand how. if I remove the endstop Y for example , the motor blocks, I must stop and I cannot try Z.
1.I mean you can exchange the endstop switches of Y axis and Z axis each other to see if the endstop switch of Z axis is bad.
2.Check the back of the motherboard if there is a soldering problem in Z_min pin like the following picture shows:
