Page 4 of 5
Re: Delta Rostock mini G2 dual firmware for GT2560
Posted: Sun Jul 26, 2015 2:45 pm
by sagat
Hi, I am not able upload modified your firmware with my parameters. After check compilation there is issue with missing time.h . Can you help me somebody?
Posted: Sun Jul 26, 2015 2:46 pm
by sagat
Posted: Sat Aug 08, 2015 6:38 pm
by LindaJ
I have a strange issue.. when i want to home X Y and Z, X and Y works ok but Z only goes up a few millimeters. if I keep homeing, it crashes against the stop sensor.
I have not been able to get this to go.
Posted: Sat Aug 08, 2015 6:49 pm
by LindaJ
also.. i am showing Err: MINTEMP
and on Repeteer i get this
Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
N353 G91 *52
N354 G1 Z-1.00 F300.00 *57
N355 G90 *51
Posted: Mon Aug 10, 2015 7:57 pm
by moriartynz
I had a similar situation with my G2S. The stepper motor driver daughterboard appears to be faulty (or misconfigured or something). You can test this by swapping the daughter boards around with Z and X (or Y) and seeing if the same thing happens on the swapped axis. If it does then it is a stepper driver issue not a firmware issue. Remember to do this when all the power is off.
Posted: Fri Dec 25, 2015 2:08 am
by DQW
I get this and I cannot achieve to upload anything on the board! Prusa I3 x with GT2560 + A4988
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_command(): failed miserably to execute command 0x11
avrdude: stk500v2_disable(): failed to leave programming mode
anybody solutions??
Posted: Fri Dec 25, 2015 11:44 am
by Mark
how about the baud rate and use the arduino1.0.1?
And you can check the link here:
http://www.geeetech.com/forum/viewtopic ... 13&t=17102
Posted: Fri Dec 25, 2015 9:32 pm
by DQW
Yes same baudrate and arduino 1.0.1 on Mac osx Capitain.
Now going to try windows 8.1
Posted: Fri Dec 25, 2015 10:21 pm
by DQW
Tried in Windows 8.1 with arduino 1.0.1 and the firmware uploaded perfectly.
Everything loaded up correctly. now to fix the z axis from being stuck.
Posted: Sat Dec 26, 2015 3:09 pm
by Mark
If you use MAC os, then the baud rate should be 115200, and set the same value in printer settings and the firmware.
