Z home with autolevel
qdshombre
Re: Z home with autolevel
Post by qdshombre »
1
if I change Y with Z , I cannot test Z because I have to test X and Y before and Y cannot work , the Y motor dont stop. so I cannot test Z because I have to unplug .
2
no problem of welding because the contact functioned with the switch before the sensor
i3 Pro C double extrudeur MK8 - carte GT2560 avec 5 A4988 - lit chauffant
qdshombre wrote:1
2
OK,what kind of sensor are you using?Attach a pic if possible.
qdshombre
Post by qdshombre »
how to test otherwise z home?
qdshombre
Post by qdshombre »
here. how to test otherwise z mini?
qdshombre wrote:here. how to test otherwise z mini?
I think you can refer to the two posts,they must be helpful to you:
http://www.geeetech.com/forum/viewtopic ... 18&t=17341
http://www.geeetech.com/forum/viewtopic ... 18&t=17004
qdshombre
Post by qdshombre »
but I have already seen these posts, my circuit proposed page 3 is not good? this is exactly the same idea.
How can I test my Z min?
Cup
Post by Cup »
qdshombre wrote:but I have already seen these posts, my circuit proposed page 3 is not good? this is exactly the same idea.
Where you bought the sensor?The seller didn't give you a user manual??And can't you plug the sensor connector into the Z_max port?
qdshombre
Post by qdshombre »
Cup wrote: Hi,
The sensor is not a problem, only 3 cables.
Cup wrote: And can't you plug the sensor connector into the Z_max port?
Maybe if Z min is faulty but I do not know how to test Z min.
Cup
Post by Cup »
Why did you say that?You said "the contact functioned with the switch before the sensor" before,and it means the Z_min port has no problem,doesn't it?
qdshombre
Post by qdshombre »
Cup wrote:Pourquoi avez - </font><font>vous dit? vous avez dit "le contact a </font><font>fonctionné avec l'interrupteur avant que </font><font>le capteur" avant, et cela signifie que </font><font>le port Z_min n'a pas de </font><font>problème, non?</font></font>
I don't know, it does not work now from the sensor
