For people who wants STL files of parts
Re: For people who wants STL files of parts
Hi,@KiloVolT
Could you please attach a picture of the mentioned part?
Maybe i can help you get it.
x20011
Post by x20011 »
Does the PI3B-B03 carriage fit for the "Geeetech i3 Pro C".
I want to change my Dual direct drive extruder to Single bowden extruder with Autobed Level....
leonmarkus
Post by leonmarkus »
Are there some .stl files available for the METAL parts of the newer Geeetech Prusa i3 Pro B?
Would be really handy for designing things in CAD.
Thank you!
There are no STL files for new Pro B.
Lami René
Post by Lami René »
Bonjour,
Voici quelques pièces pour l'imprimante 3D Delta Geeetech Rostock 301 :
https://www.thingiverse.com/thing:2464177
Voir aussi :
http://forums.reprap.org/read.php?178,781375,781375
L'ami René
One for all and all for one !
JustinSB
Post by JustinSB »
I have a Pro W (which is, of course, cut from plywood). If I want to modify/upgrade/add bits, does it have the same fittings as the Pro B...? If not, what should I use instead?
gyany_eugen
Post by gyany_eugen »
I have a Geeetech I3 Pro W (wood frame) and I need stl files for Y belt holder. At least the only piece which is from plywood.
Is there any chance to find stl files for this printer?
Thank you!
gyany_eugen wrote: Sun Mar 11, 2018 4:52 pm Hello.
Thank you!
I will check ,if I have this part stl files. I will send it to you.
moi
Post by moi »
hi can anyone yell me if there is a stl available for the i3 pro b acyrilic z motor frame part, i broke one during assembly, really would appreciate some help to find this part to print.
best regards
:mrgreen:
Enter the part number & show photos of the required item. I will see what can be done.
