Z home with autolevel
qdshombre
Re: Z home with autolevel
Post by qdshombre »
no one? no technician available? Tuesday, it's been a month that I'm out ??? !!!
i3 Pro C double extrudeur MK8 - carte GT2560 avec 5 A4988 - lit chauffant
qdshombre
Post by qdshombre »
maybe stop Z min and using Z max? how to change? thank you
qdshombre wrote:maybe stop Z min and using Z max? how to change? thank you
Sorry for the late reply.
1.Open you firmware file,and find "pins.h",then open the file with your WordPad on your PC:
2.Then modify the codes of red area like the following shows:
#ifdef Z_STOP_PIN
#if Z_HOME_DIR < 0
#define Z_MIN_PIN Z_STOP_PIN
#define Z_MAX_PIN -1
#else
#define Z_MIN_PIN -1
#define Z_MAX_PIN Z_STOP_PIN
#endif
#endif
#ifdef DISABLE_MAX_ENDSTOPS
#undef X_MAX_PIN
#undef Y_MAX_PIN
#undef Z_MAX_PIN
#define X_MAX_PIN -1
#define Y_MAX_PIN -1
#endif
#ifdef DISABLE_MIN_ENDSTOPS
#undef X_MIN_PIN
#undef Y_MIN_PIN
#undef Z_MIN_PIN
#define X_MIN_PIN -1
#define Y_MIN_PIN -1
#endif
to this:
#ifdef Z_STOP_PIN
#if Z_HOME_DIR < 0
#defineZ_MIN_PIN -1
#else
#endif
#endif
#undef X_MAX_PIN
#undef Y_MAX_PIN
#undef Z_MAX_PIN -1
#define Z_MAX_PIN
#endif
#undef X_MIN_PIN
#undef Y_MIN_PIN
#undef Z_MIN_PIN
#define Z_MIN_PIN
#endif
You can have a try.
Good Luck
qdshombre
Post by qdshombre »
thanks, I'll try. my sensor is NPN NO, it's okay?
Toy
Post by Toy »
qdshombre wrote:thanks, I'll try. my sensor is NPN NO, it's okay?
It's okay since it's a NO sensor.
qdshombre
Post by qdshombre »
NPN PNP (Copier).jpg (15.03 KiB) Viewed 8447 times
Toy wrote:Il est correct car il est un capteur de NO.
ok, but mine is NPN but it is connected as a PNP on the attached model. Not a problem?
