Re: 3d touch sensor g-code and endstop issues
Posted: Mon Dec 17, 2018 7:30 pm
ok so the 3 pin wire seen below for 3d touch isn't correct? I should split the 3 pin connector to the z max?
http://forum.geeetech.com/
The pic of yours is the motherboard GT2560A+.mudmarron wrote: Mon Dec 17, 2018 7:30 pm ok so the 3 pin wire seen below for 3d touch isn't correct? I should split the 3 pin connector to the z max?
Could you tell us your printer model?mudmarron wrote: Fri Dec 28, 2018 7:21 am I've done that. I am starting to think I have a faulty sensor.
Does anyone know what voltages etc. I should see on each pin when powered up?
It does the test up and down on the pin but if you input the G code nothing happens.
When I try to zero the z axis it just drives into the bed, or if I change the sensor 3 pin upside down it will just go up about 10mm then stop.
