printer not working after changing circuit board
nutts
Re: printer not working after changing circuit board
Post by nutts »
Ok This time this is going to work
I have downloaded Arduino 1.6.9
I have fixed the com 2 port
It is running Baud rate 250000
Now I will try to up load the firmware and see what happens
nutts
Post by nutts »
I have tried to up load the firmware but I got a fail
What am I doing wrong ?
I will bet that you did not think you run into somebody as stupid as me!!!!!
appswert
Post by appswert »
nutts wrote:I have tried to up load the firmware but I got a fail
What kind of error message do you get?
Or what text appeares in the Arduino IDE console...
Because last time I tried to compile the Geeetech firmware I had issuses too. Can you try to compile it without uploading (the symbol next to upload (left))?
How far do you get? Compiling? Uploading?
And don't worry... You aren't dumb... It took me two days to get my chinese Arduino clone with an exotic serial-to-usb chipset to work with arduino IDE :)
And you managed to assemble a 3d printer right?
appswert
Post by appswert »
nutts wrote:Ok This time this is going to work
The Baud rate is only relevant if you use the arduino IDE terminal to send messages like the G or M codes...
For upload the Arduino IDE automatically determines the correct speed setting (its preprogrammed in the bootloader).
nutts
Post by nutts »
Now I get " invalid pre-processing directive #A
appswert
Post by appswert »
nutts wrote:Now I get " invalid pre-processing directive #A
Ok thats an Compilation error (source code gets translated into machine code)
An preprocessing directive is something like "#define" or "#ifdef"
So its an fault of Geeetechs supplied firmware I think. Wait a minute, i will try to compile it and see where the error occurs...
appswert
Post by appswert »
Ok I'm getting compilation errors too...
I'll try to set up a version of marlin 1.1 for your board...
appswert
Post by appswert »
OK finished...
1) Unpack the .zip
2) Open Marlin.ino
3) Hit compile... Are there still any errors?
4) Upload and test (I don't know if the formware will work as expected so test it a bit / I can't test it because I don't have the same printer.)
5) Does the knob work now? (It might need 4 steps to jump from option to option)
Marlin-1.1.x_i3proB.zip
Marlin Firmware 1.1.x hopefully working on pro b
(867.02 KiB) Downloaded 508 times
nutts
Post by nutts »
Well Still no motors working
But LCD now says its a Ultimaker
So I think it's the wrong controller
But it did load the firmware
Finally some progress !!!!!
nutts
Post by nutts »
I think the LCD was a REPRAP DISCOUNT SMART CONTROLLER
