Geeetech A10 firmware Marlin 1.1.9
Re: Geeetech A10 firmware Marlin 1.1.9
I've flashed this firmware but now hotend max temp is 235° while it should be 250° and heatbed is locked at 100° while it should be 110°, based on official user guide.
How can I fix this ?
Search the .ino file in the zip folder and open IT in the Arduino IDE. Open the configurarion.h tab and change the HEATER_0_MAXTEMP and the Bed Maxtemp. Then compile and upload IT via Arduino IDE
If you want a maximum of 250 you habe to Set the temperature to 265 and for the Bed also +15 to your desired value
Hello there,
I've updated my A10 just bought, but now in the "board info" , the board appears as Ultimaker, when previously was GT2560 (the real board), Is it a problem??. As a noob in 3d printing, now I dont know how to reset the firmware to the beginning state. Any advice?
Thanks in advance
Thanks in advance
I think if the pins.h file is correct.CuRock wrote: Thu Feb 14, 2019 7:33 pm Hello there,
Thanks in advance
Then it won't be a problem.
You are correctvert wrote: Mon Feb 18, 2019 10:19 pm In older versions of Marlin the 2 pins files are nearly identical the gt2560 is an ultimaker clone.
There's a 1.1.9 version on marlin's github, is it the one you modified to work on A10 ?
I think you can download the Marlin2.x for A10.entretoize wrote: Tue Feb 19, 2019 11:11 pm There's a 1.1.9 version on marlin's github, is it the one you modified to work on A10 ?
Try to find vert's post then you can download it.
OK, but this is again some sources from someone, and we don't know what it is based on exactly. How to start from the marlin offical code and make it work for A10 ? Is it explained somewhere ?William wrote: Wed Feb 20, 2019 9:33 am I think you can download the Marlin2.x for A10.
This link :
viewtopic.php?f=98&t=61991
