How to install the firmware for GT2560
Locked
Docent
Re: How to install the firmware for GT2560
Post by Docent »
Hi!
I can not replace the firmware on my Prusa I3 pro B.
I do everything according to the instructions from the first page, and when it comes to downloading
I get a message
avrdude: stk500v2_getsync(): timeout communicating with programmer
AVR Part : ATMEGA2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel STK500 Version 2.x firmware
Programmer Model: Unknown
avrdude: Send: . [1b] . [01] . [00] . [02] . [0e] . [03] . [90] . [85]
avrdude: Recv:
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv: . [07]
avrdude: Recv: . [dc]
avrdude: Recv: . [fa]
avrdude: Recv: } [7d]
avrdude: Recv: M [4d]
avrdude: Recv: . [f9]
avrdude: Recv: . [0e]
avrdude: Recv: . [10]
avrdude: Recv: . [08]
avrdude: Recv: . [16]
avrdude: Recv: ( [28]
avrdude: Recv: . [f8]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
The monitor of the port of Arduino IDE responds to the baud rate of 250000
start
echo:Marlin1.0.0
echo: Last Updated: Jan 4 2016 19:03:56 | Author: (John, default config)
Compiled: Jan 4 2016
echo: Free Memory: 3795 PlannerBufferBytes: 1232
echo:Hardcoded Default Settings Loaded
echo:Steps per unit:
echo: M92 X78.74 Y78.74 Z2560.00 E105.00
echo:Maximum feedrates (mm/s):
echo: M203 X400.00 Y400.00 Z2.00 E45.00
echo:Maximum Acceleration (mm/s2):
echo: M201 X1400 Y1400 Z100 E80000
echo:Acceleration: S=acceleration, T=retract acceleration
echo: M204 S1400.00 T5000.00
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
echo: M205 S0.00 T0.00 B20000 X13.50 Z0.30 E5.00
echo:Home offset (mm):
echo: M206 X0.00 Y0.00 Z0.00
echo:PID settings:
echo: M301 P19.86 I1.00 D98.93
echo:SD card ok
I need to change the number of motor steps.
Are there other ways for this purpose?
I spent 8 hours today and could not do anything.
Tell me the solution plz!
Master Chris
Post by Master Chris »
hi guys
My geeetech prusa i3 pro afer i tried to do firmware update now the lcd screen has 2 lines of blocks and nothing else shows also i have a high pitch squeal all the time the printer is turned on or when my computer is attached.
when i tried again to u
thankpload firmware the upload stops with an error
any help to get this working again would be apreciated
thanks
Chris
Master Chris wrote:hi guys
thanks
Chris
Hi,Please check this post and you can find the solution:http://www.geeetech.com/forum/viewtopic ... 23&t=17040.
Master Chris
You make it sould so simple lol
the problem is the file will not verify it come up with an error
so I cant upload the firmware ?
thanks any help would be apreciated
Chris
Master Chris wrote:You make it sould so simple lol
Chris
Could you show the detail about the error?
Master Chris
Ok I habve managed to upload the firmware, and it was my fault it didnt load up , I have both the 1.01 version of arduino and 1.8 and every time I tried to load the firmware it would open in the later version so would have the error i was getting, when i finally managed to open the firmware in 1.0.1 error was gone and all has loaded and my squealing and screen has returned to normal. thanks for being so patient and i apologise for waisting your time instead of double checking everything my end.
now for the bad news lol
I cant use the manual settings in Repetier or print from this software i can connect to the com port but none of the controls seem to work please help again
thanks
Chris
Master Chris wrote:Ok I habve managed to upload the firmware, and it was my fault it didnt load up , I have both the 1.01 version of arduino and 1.8 and every time I tried to load the firmware it would open in the later version so would have the error i was getting, when i finally managed to open the firmware in 1.0.1 error was gone and all has loaded and my squealing and screen has returned to normal. thanks for being so patient and i apologise for waisting your time instead of double checking everything my end.
thanks
Chris
Here are some tips for your case:
1、Try to change different value of the baud rate in the printer setting;
2、Reinstall the board driver which you can find in user manual;
Taking some video about you lastest case if it still don't work,because it will be much clearer to locate the key point.
Inferno
Post by Inferno »
OK, I'm lost.
I have my printer up and working, just fine. I want to save the Xsteps and Ysteps setting that I got after calibrating but every time I power down the machine it loses the values I put in.
Where, in the firmware, do I update those values?
Prusa i3 model with the GT2560 board.
Hi,after everytime you change the value of Xsteps and Ysteps setting ,you need to store the memory at Main>Control>Store memory.
Locked
