Latest Marlin bugfix-1.1.x branch for PI3 Pro B
Rv8
Re: Latest Marlin RCBugFix branch for PI3 Pro B
Post by Rv8 »
I test my solder, there is no short circuit between positive and signal and negative pins.
between positif and negative I mesure 149 ohms on the gt2560 board
I take a picture and I give you that
Rv8
Post by Rv8 »
this is a picture.
the solder is on z max pin
Rv8
Post by Rv8 »
I try something maybe we found it !
I remove a support in plastic, a small white part where we fix all endstop swith because the 3d sensor two wires are not enough push in the support on the board maybe this create a false contact.
because now I have this when I do M119;
21:15:05.298 : Reporting endstop status
21:15:05.298 : x_min: open
21:15:05.298 : y_min: open
21:15:05.298 : z_min: open
Rv8
Post by Rv8 »
I test with
Send M280 P0 S10 (it will push the pin down, led should be off, do not touch it)
Send M119
I have this result, I confirm led is off and pin is down
21:20:49.952 : Reporting endstop status
21:20:49.952 : x_min: TRIGGERED
21:20:49.952 : y_min: open
21:20:49.952 : z_min: open
NiklasO
Post by NiklasO »
Rv8 wrote:I try something maybe we found it !
Your soldering looks good!
You could solder the wires to the Z min pins too (front or back of board), then you will have good connection.
Rv8
Post by Rv8 »
I have only X who return propely to home.
Z axis hit the end of the printer and Y stop before y endstop is trigger !?
very strange...
NiklasO
Post by NiklasO »
Rv8 wrote:Thanks :)
very strange...
Does it hit Z max or min?
Rv8
Post by Rv8 »
It hit y min sorry ...in fact it it because the end stop is replace by 3d touch sensor "black and white wire"
NiklasO
Post by NiklasO »
Rv8 wrote:It hit y min sorry ...in fact it it because the end stop is replace by 3d touch sensor "black and white wire"
Does the probe go down when sending G28?
Rv8
Post by Rv8 »
I just send G28 and all axis seems want to go home but Y axis hit the printer so I push the urgence button..
