9 DOF weird data readings
Posted: Thu Feb 13, 2014 8:19 am
Dear Geeetech-team,
i bought a few days ago the ArduIMU 9 DOF (http://www.geeetech.com/arduimu-9-degre ... p-535.html) and I set it up and used the software of the AHRS tutorial (https://github.com/ptrbrtz/razor-9dof-a ... i/Tutorial). Of the software I only changed the fact that I am using the (#define HW__VERSION_CODE 10736 // "SEN-10736" (HMC5883L magnetometer)) version.
However, when clicking on the serial monitor (Arduino Pro ATmega328, the correct baud rate and the correct serial port), I get weird results :/ An example of these weird readings is attached to this post.
With this kind of data the module is kind of useless for me
I would appreciate your help and advise regarding this topic
Thank you very much in advance for your help and best regards!
