Page 1 of 2
Me creator problem
Posted: Tue Jan 13, 2015 5:22 pm
by Kpi1986
Hi!
When i´m trying to print something in the Me Creator, and its printing about 5 minutes or less, the extruder become blocked. I dont know what can i do for this, because i cant print nothing :(
I'm using ABS at 235ºC, and printing between 40mm/s and 60mm/s
In this video you can see the extruder when its blocked
https://www.youtube.com/watch?v=eaZ1OS6 ... e=youtu.be
Thank you
Re: Me creator problem
Posted: Tue Jan 13, 2015 6:30 pm
by john
Extruder Jamming is a normal problem and many 3D printers may get this problem, Many reason may result it.
I don't know the detail in your description,so I can't point out the reason for your problem,you can get some helps by visiting the websites following although, they show some tips we collected in the past.
http://www.geeetech.com/wiki/index.php/ ... w_Problems
http://www.geeetech.com/wiki/index.php/ ... k_a_nozzle
http://www.geeetech.com/wiki/index.php/ ... D_printing
Posted: Tue Jan 20, 2015 2:47 pm
by ooi888
Hi Kpi1986, you are lucky filament blocked after 5 units. My unit blocked after first layer. I need good advice. Wonder any MeCreator sold can print?
Posted: Sat Mar 14, 2015 4:35 pm
by zhangxueyou
Hi,ooi888
Can you manually extrude the filament? If you can ,did you set the correct extrusion width? if its value is to high, that may cause it blocked
Posted: Sat Mar 14, 2015 9:52 pm
by ooi888
Hi zhangxueyou,
I can extrude manually, extrusion width was set correctly. The clogging is caused by filement already melt before reaching the tip of the extruder.
Posted: Mon Mar 16, 2015 9:50 am
by zhangxueyou
So, ooi888, your Estep is?
Posted: Thu Mar 19, 2015 12:50 am
by ooi888
My estep is as per default, I did not reload the firmware.
Posted: Thu Mar 19, 2015 9:18 am
by zhangxueyou
Maybe the default value is wrong. It'd better be 95-100.
Posted: Wed Apr 15, 2015 4:32 pm
by ooi888
my e-step is 95. The filament clogged after 2-3 layers of printing. I received the machine last year, tried very hard to troubleshoot, but still not able to print.
Posted: Wed Apr 15, 2015 4:58 pm
by zhangxueyou
How about increasing the distance between nozzle and hot bed?
