mintemp error
mintemp error
bought a i3 pro b and got everything together, turned it on and error min temp. i got another thermistor and installed it and the same thing. now i noticed that my hot bed was not turning on either. i think its something in the firmware cause when i do a m303 or m303 E-1 C8 S90 for the autotune both the bed and extruder heat up and i get the correct temp readings. i may need the correct firmware?
zhangxueyou
Re: mintemp error
Did you connect the thermistors for hotbed and extruder to the mainboard correctly?
Re: mintemp error
yes i looked at your sites install process along with the ramp 1.4 wiki extruder in t0 and bed into t1
zhangxueyou
Re: mintemp error
Please leave your email address, I will send the firmware to you.
Re: mintemp error
how to i use this theres no .pde
Re: mintemp error
how do i load this firmware without a .pde file
Re: mintemp error
it wont allow me to use the firmware you sent without a .pde file
Re: mintemp error
this is the error message i get when i drag the fimware files to arduino ide
Arduino: 1.6.1 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
sketch_mar16a_update.cpp.o: In function `setup':
C:\Program Files (x86)\Arduino/sketch_mar16a_update.ino:1: multiple definition of `setup'
Marlin_main.cpp.o:C:\Users\ii3edus\AppData\Local\Temp\build9149531452318225068.tmp/Marlin_main.cpp:433: first defined here
c:/program files (x86)/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.8.1/../../../../avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
C:\Program Files (x86)\Arduino/sketch_mar16a_update.ino:1: multiple definition of `loop'
Marlin_main.cpp.o:C:\Users\ii3edus\AppData\Local\Temp\build9149531452318225068.tmp/SdFile.h:36: first defined here
collect2.exe: error: ld returned 1 exit status
Error compiling.
enabled in File > Preferences.
Error compiling.
zhangxueyou
Re: mintemp error
Please check your email.
