Page 1 of 2
Z axis motors underpowered?
Posted: Wed Mar 25, 2015 6:53 pm
by Zorce
My Z axis motors work when not connected to the threaded rods but once they are connected they dont move. They just seem to hum.
I have the jumpers plugged in per instructions. Are they just underpowered? Any fix for this?
Video example below.
https://www.youtube.com/watch?v=q-CHp0JtwuE
Re: Z axis motors underpowered?
Posted: Thu Mar 26, 2015 2:54 pm
by zhangxueyou
Sorry, your video is private, I can't see it.
Posted: Thu Mar 26, 2015 3:23 pm
by Zorce
Sorry, I fixed it. Should be good now.
Posted: Thu Mar 26, 2015 3:46 pm
by zhangxueyou
Can you manually rotate the couplings above z motors?
Posted: Thu Mar 26, 2015 4:06 pm
by Zorce
If I loosen them yes but they are tight on there. I can take motors lose and the motors work fine. If I unplug 1 motor, the other one will turn the rod with no problem. It is a power issue. Should I up the power pot on the stepper board? Have you seen this issue before? I see other issues like it online but no solution yet.
Posted: Thu Mar 26, 2015 4:46 pm
by zhangxueyou
Please rotate the screw on Z motor driver until the voltage between the screw and GND is 1V.
Posted: Thu Mar 26, 2015 5:47 pm
by Zorce
That seemed to have fixed the issue.
Thanks for the help.
Posted: Thu May 07, 2015 4:00 am
by Edvash
Hi there, i have the same problem
could you please explain to me what do you mean by that fix?
where do i measure the Voltage?
thanks
Posted: Thu May 07, 2015 10:12 am
by zhangxueyou
Edvash wrote:Hi there, i have the same problem
thanks
You can see there is a screw on A4988, rotate it.
Use a multimeter to test the voltage between that screw and ground.
Posted: Thu May 07, 2015 2:02 pm
by Edvash
I have tried that, the screw is very jumpy, i can't fix it on 1V
it jumps from 0.3V to around 4.5V in the slightest turn of the screw.
