LCD showing blocks after RAMPS flash. Nothing works anymore
Civiking84
Post by Civiking84 »
Blocks
Blocks
As the title says. I recently flashed the board, and now nothing works. Before the flash, I could home the axis but not adjust any other direction in Repetier host. Now I can do nothing. And the screen looks like this when powered on
zhangxueyou
Re: LCD showing blocks after RAMPS flash. Nothing works any
Post by zhangxueyou »
Did you change anything of the firmware? Or Did you change something in a file by accident?
Civiking84
Nothing was changed. I tried multiple times re flashing the board and it still does the same thing. I used the file I was sent and all 63 items went to it. It still connects in Repetier but I cannot control anything. It says 2 movements pending.
john
Post by john »
Did your LCD display right before, even once? How about it when you first used it? We need to confirm it's a software or a hardware issue.
Civiking84
Yes it worked. And I could home the axis. Now the screen shows that and nothing else works. I've requested a refund already. I purchased a different brand that I have received and it is working.
