Extruder problems
Posted: Mon Mar 30, 2015 6:46 pm
by Kuryu
I have the same problem of this link
http://www.geeetech.com/forum/viewtopic ... 14&t=16050
With spring 100% stretching the engine makes a noise as it would be jammed, if I push the filament with my hand and help everything goes well, if I push the spring stop making noise and the wheel tooth slide in the filament, do not push
The temp:250c for Abs
I think it can be solved increasing the intensity of electricity, on the chip regulator. What do you think?
The machine is i3 acr, 0,3 and filament 1,76 abs and motheboard is a sangui.
All jumps ok
All chips ok
The temp is ok
Re: Extruder problems
Posted: Tue Mar 31, 2015 6:00 pm
by zhangxueyou
How about your silcer settings?
Posted: Tue Mar 31, 2015 6:18 pm
by Kuryu
Could you please send me the correct settings for the slicer? And please tell me how to load the configuration on the programm because I have no idea how to do it. You can send me screen shoots and I modify it manually
Now configuration layer 0.2 first 0.3 and filament 1.75
Posted: Wed Apr 01, 2015 5:56 pm
by zhangxueyou
Try this.
slicer settings(1.75-0.3).rar
(719.11 KiB) Downloaded 490 times
