Repetier-Host setting on ABS print
animetown9
Post by animetown9 »
I was wondering any have a good setting for Acrylic Geeetech I3 pro B 3D Printer
Repetier-Host, windows 7
Filament 1.75 , nozzle 0.5mm
ABS filament.
thank
zhangxueyou
Re: Repetier-Host setting on ABS print
Post by zhangxueyou »
Actually, you just need to modify the nozzle diameter and layer height.
slicer settings(1.75-0.5).zip
(569.25 KiB) Downloaded 1974 times
leonardo.galardi@gmail.com
Post by leonardo.galardi@gmail.com »
I see Extrusion multiplier = 0.6 in Filament Settings, ABS 1.75 mm. Why ? I think it should be 1, right ?
zhangxueyou
It's hard to say. You can try 0.6 and 1 respectively.
axenias
Post by axenias »
Hello friends, do you know if these settings are good for nozzle 0.4 too???
I think it will be ok, but I think layer height is too big, I can give you my settings for ABS, using repetier1.6.0 and 1.75-0.4 ,single I3X printer.
config ABS.rar
(1.29 KiB) Downloaded 1716 times
axenias
Post by axenias »
Ok, well, thank you! I have an i3 pro b printer. I will give a try to your config.
axenias
Post by axenias »
Hello again, i was wondering if there is some ready config for the same bodel but for cura, not repetier! Is anyone know if i3 pro b can play with cura 15.04.3??
Thank you!
I could run the printer with the built-in cura engine in repatier host 1.6.0, so I guess it will be fine.
