Marlin firmware
Posted: Sat Apr 11, 2015 9:18 pm
I buy a geeetech prusa I3 pro B with ramp 1.4
Where can I find the marlin firmware preconfigure ?
http://forum.geeetech.com/
Hi, I too bought the I3 pro B (one that prints 5 types of filament), I'd like to have the firmware also.zhangxueyou wrote:Please leave your email address , I will send the firmware to your email.
Hi, Vicoz2009Vicoz2009 wrote:Looks like I am having issues with the firmware you've supplied (prints were corrupting 2-3hrs into the print), I've downloaded the current version of Marlin and applied the i3 Pro B settings and have completed 2 long prints (3hrs+) successfully so far. Will keep testing with the new firmware (1.0.3).
Can someone please advise where I may set the 'home' location so that the extrusion head is sitting above the front left corner glass, and not the hex nut?
Sorry, the axis will stop as it touches endstop. Generally, the nozzle will be above the front-left corner of glass, not above the hex nut. If you really want the nozzle exactly above the front-left corner of glass, I suggest you re-design a x-motor holder to change the location of x endstop.Vicoz2009 wrote:My Z travel is fine, its actually the X and Y. I was hoping there is something in the firmware that I can change this. I saw somewhere it can be changed via GCODE but that would be temporary only.
Hello, to protect the extruder motor, it can not unless the temperature is more then 180 degrees.vinokuryakov wrote:I got Geeetech I3 Pro 3D printer with Sanguinololu controller v. 1.3a. My Y and Z axis are working fine. X and Extruder do not work when controlled via LCD2004 panel. When X and Extruder motors are connected to Y port of the controller they work when changin Y position. Swapping driver modules did not help. Next step I would like to reload the firmware. Can you please prodive the link for it?
Thank you.
Jacob
