Page 1 of 2
My slicer settings
Posted: Sat May 09, 2015 10:37 am
by zhangxueyou
I use Geeetech Prusa i3B, with 1.75mm filament and 0.3mm diameter. Slicer software is Slic3r. Attachment is my slicer settings, I got good print with these settings, you can try.
Actually, anyone who uses different kinds of printer, or the same printer with different filament diameter or nozzle diameter, can also refer to this setting. But you have to change some parameters in slic3r, including "filament diameter", "nozzle diameter", "first layer height"(it is as same as nozzle diameter), "other layers height"(I suggest lower than first layer for 0.05-0.1mm).
slicer settings(1.75mm-0.3mm).zip
(388.83 KiB) Downloaded 2291 times
Re: My slicer settings
Posted: Tue May 12, 2015 5:24 pm
by zhangxueyou
You can also load the configuration file directly.
import slicer setting 1.png (46.16 KiB) Viewed 45117 times
Open slic3r in Repetier Host:
import slicer setting 2.png (52.58 KiB) Viewed 45117 times
import slicer setting 3.png (87.36 KiB) Viewed 45117 times
slicer config.zip
(1.27 KiB) Downloaded 1923 times
Posted: Wed Jun 03, 2015 2:23 am
by johnz
What speed on the feed rate and flow rate??
Posted: Wed Jun 03, 2015 10:04 am
by zhangxueyou
johnz wrote:What speed on the feed rate and flow rate??
1 or 1.1 maybe.
Posted: Wed Jun 03, 2015 10:23 am
by johnz
Ok how about on the Repetier v1.0.6
Posted: Wed Jun 03, 2015 10:29 am
by zhangxueyou
johnz wrote:Ok how about on the Repetier v1.0.6
I use Repetier1.0.6 exactly. And I use the slicer settings as the attachment above, and it prints fine.
Posted: Sat Aug 27, 2016 1:16 pm
by thhale
Thanks for sharing.
Posted: Mon Dec 26, 2016 3:17 am
by gpau
where I find the slicer setting for mac Ios?
Thank you
Posted: Wed Dec 28, 2016 1:50 pm
by Cup
@gpau
So the Mac version doesn't recoganize the .ini format file?
Posted: Fri Feb 10, 2017 6:58 am
by gpau
@cup
ok,
I can get it for windows
thanks
