How to start Geeetech I3 Pro C in Repetier-Host
Posted: Tue May 26, 2015 3:02 pm
by zhangxueyou
Open Repetier-Host (Download link:
http://www.repetier.com/download-now/), Access "Printer settings":
- QQ截图20150526094205.png (133.12 KiB) Viewed 42917 times
Set correct baud rate and serial port:
- choose baud rate and serial port.png (23.6 KiB) Viewed 42865 times
Set amount of extruder as 2, and set correct nozzle diameter:
- QQ截图20150526094443.png (29.43 KiB) Viewed 42917 times
Then you can control both extruders on Repetier-Host (
Note:The extruder can not move unless the temperature is more than 180 degrees):
- QQ截图20150526145044.png (75.72 KiB) Viewed 42917 times
Slicer setting:
To have a good 3D item,you need to have a good slicer setting, and distribute jobs for 2 extruders:
Click "configuration" to access slicer setting:
- QQ截图20150526094538.png (86.4 KiB) Viewed 42917 times
For more details of sclicer setting, you can download the attachment to refer:
Re: How to start Geeetech I3 Pro C in Repetier-Host
Posted: Wed Mar 16, 2016 11:37 am
by lobbo1979
Posted: Wed Dec 28, 2016 10:29 am
by AbeFM
Could you save the slicer settings as a file that can be loaded instead of as a series of photos?
Posted: Wed Dec 28, 2016 10:48 am
Did you notice this?
slicer settings for I3C.zip
(740.38 KiB) Downloaded 169 times
Posted: Wed Dec 28, 2016 12:08 pm
by AbeFM
AbeFM wrote:Could you save the slicer settings as a file that can be loaded instead of as a series of photos?
Did you notice this part?
I mean a file with the settings which we can load directly.
Posted: Tue Jan 12, 2021 1:32 am
by Galas
Thanks for the information. And can I combine several printers in one program. For example, I will have one template and the same settings but two printers. Is it possible?
Posted: Thu Nov 25, 2021 3:39 pm
by imrozahmad
Posted: Mon Dec 06, 2021 7:18 pm
by LucyKelly
Thank you for providing this information. Is it possible to combine multiple printers into a single program? I want to print out the images of the
drift hunters game, a speed racing game. Is it possible?
