Page 1 of 2
No Movement with extruder and heating bed on, otherwise fine
Posted: Mon Jun 01, 2015 8:59 am
by XYZM
Its a puzzle
When I run a job with the extruder cold, the X Y Z motors move just fine.
But when I heat the extruder then run job, a piece of filament comes out but the XYZ motors do not move and just make alot of noise.
What do I do??
Re: Loud vibration. No Movement. Only When Running Job...
Posted: Mon Jun 01, 2015 10:58 am
by zhangxueyou
Please try to print without heating the bed.
Posted: Mon Jun 01, 2015 11:08 am
by XYZM
Yes I noticed the loud noise does not happen when the heat bed is not on.
Why would this make a difference?
Posted: Mon Jun 01, 2015 11:11 am
by XYZM
But that is only temporary, when I try to print with the extruder on and the heat bed off the motors start to stutter again.
before I was just using manual controls to test.
Posted: Mon Jun 01, 2015 11:22 am
by zhangxueyou
I think it is the power supply issue, so when you let all the part work together, they can not work fine. If you have another power supply, it can be confirmed.
Posted: Mon Jun 01, 2015 11:36 am
by XYZM
This is the only power supply provided in the package.
Posted: Mon Jun 01, 2015 11:41 am
by XYZM
When I try reducing all the voltages I get barely any movement at all.
And counterclockwise on the drv board does not always make the voltage lower. Sometimes It jumps up.
Posted: Mon Jun 01, 2015 11:42 am
by zhangxueyou
Now that all the components can work separately, the mainboard is fine. But they can not work together, because power supply can not provide enough power, so I think you have to replace a new one. Please contact customer service.
Posted: Mon Jun 01, 2015 11:48 am
by XYZM
I bought this through an ebay sale. Can you communicate with them so they can provide a new power supply? I bought the printer through Lemon
From ebay
"Skype: lemon.wang67
Whatsapp: +8615011851995
email: lemon.wang (@) geeetech.cn"
Posted: Mon Jun 01, 2015 11:58 am
by XYZM
Are the power supplies for The B and C model the same?
