X,Y, & Z axis motors do not move in manual control
Posted: Fri Jul 03, 2015 4:24 am
by VIJAY
LCD Display
LCD Display
Assembled Printer
Assembled Printer
I have now completed the assembly of the Geeetech I3 Pro B.
This has only GT2560 Control Board. I have downloaded the Repetier-Host GEEETech V0.09D
program. I am only able to make the motors move to the home position from the LCD display (Auto home).
I am not able to control the motors manually from the manual control in the program.
The display shows extruder at 0 degree, the HOT BED at 24 degrees. Err: MINTEMP. FR: 100%.
Please can you explain what are the issues at present and what needs to be done to resolve these issues.
Vijay
Re: X,Y, & Z axis motors do not move in manual control
Posted: Fri Jul 03, 2015 10:11 am
by zhangxueyou
When LCD displays "0/0", the corresponding thermistor is not well connected to mainboard, or it is plug to the wrong slot.
"Err: min temp" means extruder thermistor is not well connected.
"Err: min bed temp" means hot bed thermistor is not well connected.
You must let all the axes auto home if you want to control x, y, z separately.
Could you please take a picture of your mainboard with wiring, let me check for you.
Posted: Fri Jul 03, 2015 8:34 pm
by VIJAY
Hi Zhang,
Thanks for the response, forwarding the wiring pictures. I have removed
the LCD and SD card cable for better view.
Vijay
Posted: Tue Jul 14, 2015 12:03 pm
by Sherry
hi,according to your describe, the motor do not turn because it could not read the temperature correctly.please replug the thermistor wire and tighten it.
