The printer is not printing operation from SD card
Surfovod
Post by Surfovod »
Printer - Acrylic Prusa i3 Pro B
Board - GT2560
LSD - LCD 2004 display controller
SD Card - 2 GB Class 4
Firmware - the latest from here http://www.geeetech.com/forum/viewtopic ... 636#p25636
I can not start printing from the SD card.
Write files to the G-code on the card inserted into the printer, he writes that the SD card is inserted. Select files for printing, press "printing from SD" and nothing happens, the printer is not printing as the inscription on the display shows the "wait for user ..."
What to do?
Sherry
Re: The printer is not printing operation from SD card
Post by Sherry »
hi,surrfovod.could the printer read files in the sd card,or you could only see the folder ,n0 files?
Surfovod
Post by Surfovod »
Printer files spots but not pechatatet
Displays a message - "wait for user ..."
Surfovod
Post by Surfovod »
Hi, printer folder opens and sees the files, but not the printing operation from the SD card.
After you give the command to print the file on the screen, he pishit "wait for user ..." and nothing happens.
Sherry
Post by Sherry »
maybe the g-code goes wrong,i have sent tested g-code to your mailbox,please try and tell me the result.thx
Surfovod
Post by Surfovod »
I'll check your G-code ....
Is that the case? From a computer printer OPERATE.
Surfovod
Post by Surfovod »
I checked your test code. It is not worked. Thank you so much.
I do not understand why my nerabotatet? Maybe it's due to the fact that I use a different version of the program Repetier-Host? Or nepravelno settings Slik3r?
micJoel
Post by micJoel »
Well I had the same problem.
So when saving the GCode file ("save for sd print") with Repetier, I left the "save in binary format" option unmarked.
After that the printer worked well.
