Extruder Motor Failing to feed
Posted: Sat Aug 22, 2015 8:24 am
by IdioticAussie
When attempting to print on my G2S I get the problem of the motor failing to feed. When applying a slight bit of pressure to the spring to relieve the foce on the gear it works better but I am unable to keep it in this position. Any suggestions? It is really impacting my ability to print because no filament is being fed into the hotend
Regards
IdioticAussie
Re: Extruder Motor Failing to feed
Posted: Sat Aug 22, 2015 4:29 pm
by Mark
In this case you can adjust the screw here to get a proper tightness.
