Extruder alignment
Posted: Tue Aug 25, 2015 10:36 pm
Is there a offset setting for the dual heads ...
The test print, prints two different parts where it should be one. (that would be the test print from you guys)
What is the offset setting....how and where do I go to get it to talk to the Prusa Pro firmware
I have tried setting it in slicer using -12.5 and +12.5 and there are no results....still a mess....tried 30mm on just the 2nd extruder ...no results still a mess
is there some secret to this...?
this is after my dual head bracket melted of the printer from the heat and weight....I have since replaced the 3d printed original part with metal...
