Arduino 1.0.1 Not Showing Sanguinololu as Board
Posted: Mon Sep 07, 2015 10:42 pm
by Khilborn
I have downloaded the Aurduino and need to burn the firmware but Sanguinololu is not showing up in the list of Boards??????
Re: Arduino 1.0.1 Not Showing Sanguinololu as Board
Posted: Tue Sep 08, 2015 9:12 pm
by Mark
Did you install the driver?
Posted: Tue Sep 08, 2015 9:53 pm
by Khilborn
Yes, we had all this working fine until you guys sent me a new hotend, now the printer prints like garbage so we are redoing all calibrations.
Posted: Wed Sep 09, 2015 6:12 pm
by Mark
Did the PC recognise the COM port or not?
Posted: Wed Sep 09, 2015 9:16 pm
by Khilborn
Yes, All we did was change out the Hot End that you guys replaced. The printer was printing pretty flawlessly before we switched it out. Now it's printing like garbage.
Posted: Fri Sep 11, 2015 9:08 pm
by Mark
How about the later version of arduino ?
Posted: Fri Sep 11, 2015 9:11 pm
by Khilborn
What would the latest version of audrino do for me. The problem we are having now is this.
After putting on a new hot end the E step do not seem dictate the rate at which the filament goes through. The original firmware E step (before the new hot end) settings were set to 95. When using that setting and extruding 100 mm the filament only measured that it extruded 27 mm. I tried doubling the E steps in the firmware and I could see the motor turning faster but the same amount of filament was extruded. Any suggestions will be appreciated.
The printer was printing perfect until the hot end went. All we did was put a new hot end on.
Posted: Mon Sep 14, 2015 10:03 pm
by Mark
weird! how about changing it back?
Posted: Tue Sep 15, 2015 12:39 am
by Khilborn
Can't put it back because it caught on fire......
Posted: Tue Sep 15, 2015 5:39 pm
by Mark
If you remove the giude tube, and do not plug the filament into the hotend, manually extrude 100mm, how about the actual extrude length?
And check the driver subdivision of the extruder see if they are correct.
