Page 1 of 2
How to slove the problem of MAX/MIN TEMP error(GT2560)
Posted: Thu Oct 08, 2015 5:36 pm
by Mark
Hi guys, if your printer shows MAX/MIN TEMP error on the LCD, don't worry, you can refer to the following information to check it, good luck :D
LCD:ERROR:MAX TEMP OR ERROR:MIN TEMP
01
01
01 MAX MIN TEMP.jpg (90.18 KiB) Viewed 89061 times
Above of all,check the wiring of thermistors if you have a single extruder on your printer.The right one should be like this:
Recommended solutions:
1.1 First, check the motherboard. If you get 0℃ and 358 ℃ when you make the thermistor open circuit or short, then the board is good. You can do it as follows.
Note: If your printer is Delta G2/G2S series, before checking this please install the firmware for I3X or I3 pro C, cause when you short out the thermistors with the firmware of G2/G2S, it will always show 0 degrees on the LCD, though it is exactly MAX temp error.
Open circuit:
open circuit01
open circuit01
open circuit01.jpg (200.95 KiB) Viewed 89061 times
open circuit02
open circuit02
open circuit02.jpg (102.59 KiB) Viewed 89061 times
Short the board:
short01
short01
short02
short02
For example,the T_HE2 is shorted out.As a result,the second extruder will always display 358/0 no matter you make it open circuit or short circuit.
1.2 If the board is OK, please check if somewhere of the wire are connected or not.
For example, the thermistor is shorted out as the picture shows:
05
05
If so, the current will not go through thermistor, and LCD will display TEMP ERROR. You can refer to the following information:
MAXTEMP ERROR:
1.2.1 If it shows "358/0, room temp/0; Err: MAXTEMP". The extruder thermistor is short.
1.2.2 If it shows "358/0, 358/0; Err: MAXTEMP". Both extruder thermistor and hot bed thermistor are short.
1.2.3 If it shows "room temp/0, 358/0; Err: MAXTEMP BED". The hot bed thermistor is short.
MINTEMP ERROR:
1.2.4 If it shows "0/0,room temp/0; Err: MINTEMP". The extruder thermistor is open circuit.
1.2.5 If it shows "0/0, 0/0; Err: MINTEMP". Both extruder thermistor and hot bed thermistor are open circuit.
1.2.6 If it shows "room temp/0, 0/0; Err:MINTEMP BED". The hot bed thermistor is open circuit.
NOTE: Remember to reset the LCD after you do those experiments. And the MAXTEMP shows in the LCD is not always 385, it’s between 358 and the temperature you set in the firmware here:
#define HEATER_0_MAXTEMP 275
#define HEATER_1_MAXTEMP 275
#define HEATER_2_MAXTEMP 275
#define BED_MAXTEMP 150
1.3 If one of your thermistor is working, you can swap it with the TEMP ERROR one, and see if the thermistor is dead or not.
Hope this will help you guys, thanks!
Re: How to slove the problem of MAX/MIN TEMP error(GT2560)
Posted: Fri Feb 24, 2017 5:18 am
by terrapetros
hi guys,
i am having the same mintemp problem and i think that is everything good connected. on my lcd display it only shows "0/0,room temp/0; Err: MINTEMP".
is something wrong on the pictures ?
thanks
Posted: Fri Feb 24, 2017 2:03 pm
by bang
terrapetros wrote:
hi guys,
thanks
Did you try placing one jumper cap to the socket(to verify if the socket was broken) for the thermistor of extruder0?
Or you can plug the thermistor of heatbed to that socket then see how it shows on LCD,you can get the outcome(the socket or the thermistor itself was broken) as per that.
Posted: Thu Mar 23, 2017 9:27 am
by jeanbraga
Personally, I bought the Rostock 301 printer, I have a problem in the Extruder and in the extruder that is not heated, the LCD always shows 0 / 0º. I think it may be some printer setup, can anyone help me ??
I tried to contact the company by email and skype but, so far, does not receive any response.
Attached photos.
Please help me.
Ats
Jean Braga
----------- PORTUGUES BRASIL -------------
Pessoal, comprei a impressora Rostock 301, estou com problema nno Extruder e na extrusora que não esta aquece, no visor LCD mostra sempre 0/0º. Penso que pode ser alguma configuração da impressora, alguém pode me ajudar??
Tentei entrar em contato com a empresa por email e pelo skype mas, até o momento não recebe nenhuma resposta.
Fotos em anexo.
Por favor, me ajude.
Ats
Jean Braga
Posted: Sat Apr 01, 2017 2:56 am
by ikronos
A month ago I acquired a printer "Mecreator2 (GT2560 Rev B).", Until a week ago the printer worked correctly.
After finishing an impression, sent from Repetier, a maximum temperature error "ERR MAX TEMP" appeared. Showing the values ​​319º / 320º for the extruder, 67º / 70º for the bed.
Turn the printer off and on if this error disappears, both the extruder and the bed being at room temperature. After resetting the error, proceed as follows: ERR MAX TEMP. "Displaying the values ​​319º / 320º for the extruder, 67º for the bed.
After consulting in the Forum, the topic viewtopic.php?f=23&t=17030 without serving the solutions provided
According to the viewtopic.php?f=23&t=17030 topic,
I have disconnected the bed, and the extruder cable from the back of the printer, so thermistors should not signal, but the error after resetting, is not erased, nor does it change MAX Temp.
I have put the firmware indicated in the forum for the printer "Mecreator2" but also not be solving the problem.
The three motors of the x, y, z axis and the extruder operate correctly, but there is no way to print, as the error is not erased.
With a multimeter I measured the purple-gray and yellow-brown extruder cables with 630 and 612 ohms with an ambient temperature of 20º.
I have also measured the blue and green wires of the bed, without getting any value.
What is happening? How do I solve this problem?
J. E.
Posted: Tue Jun 06, 2017 3:23 am
by changastyle
Could anyone fix this issue? Or just keeped yours printers not working?
Posted: Tue Jun 06, 2017 8:08 pm
by terrapetros
Mine is still not working. i will bring it to a FABLAB in my city to see if someone can fix it.
:o :o :o
Posted: Fri Jun 30, 2017 2:48 am
by venum
bonjour a tous
il y a personne qui a trouver une solution a se problème ?
Posted: Tue Nov 13, 2018 1:49 pm
barker wrote: Sun Nov 11, 2018 8:10 am Hello I recently acquired my very first 3d printer. After a lot of assembly time and the replacement of a faulty engine I am going to calibrate my printer, and during a test to see if my tray was at the correct distance from my extruder, an error appeared on the "LCD ERR MAX TEMP BED" and I saw the temperature of the plate at 270 C while I could put my hand over it.This error does not allow me to print. Someone would have a solution? Thank you for your answers.
Try to replace the thermistor of hotend and heatbed.
Then you can get the result:The issue is the broken thermistor or not.
Posted: Mon Oct 21, 2019 10:09 am
by TheHyperion
I am having the same issue after installing your latest firmware. I had no temp issues prior to the firmware update and the terminstors test fine.
