solution for G2S extruder2 drives axial motors
Posted: Sun Oct 11, 2015 1:38 pm
by Mark
Hi guys, if you run into the problem that the G2S extruder2 drives axial motors when printing, you can try to solve it by reinstall the latest firmware, and change some setting here. You can have a try but ready to press the emergency button if necessary!
Download the latest firmware here:
For the distance of the two extruders is 20mm, you should set the Y offset in the printer settings and the slice software as follows.
Do note that if your spider is the metal one, the distance is 26mm!
1. printer settings:
2. settings in slic3r:
3. Add "M84 S0" to the gcode here:
If you want to add the G29 to test the auto-leveling, add it here:
If you have some problems duing the test please feed back it here, we'll try to fix it, tks!
Re: solution for G2S extruder2 drives axial motors
Posted: Fri Dec 31, 2021 1:18 pm
by xyvew
Gree tech is the advance website of making the solutions with the life lines of the achievements. These are frequently used products that can make the pattern of the australianwritings with the solution to the axial motors in the same theme of work with all of these.
