z axis problem
Posted: Thu Oct 15, 2015 5:08 am
by ehsansv
1st
when i insert sd card(1 gig) it say in homepage sd card inserted but in next menu write no sd card inserted
2nd
the z axis step motors does not work
when i click auto adjustment
i just have a zzzzzzzzz" sound(like Vibration) both of them "
hi,it seems that you SD card is broken.or you can try to fomat it .
and z axis problem,you can spread some machine oil on top plate.
Re: z axis problem
Posted: Fri Oct 16, 2015 2:57 am
by ehsansv
hi
i upload a video of that
www.galbehonar.ir/20151015_181708.mp4
Re: z axis problem
Posted: Fri Oct 16, 2015 5:48 pm
by Mark
Did you generate the gcode file? the SD card can only reads gcode files and the format is FAT or FAT32, if all those not work, then I think you should find another SD card to try it.
And z axis can not move, then how about refer to the link here:http://www.geeetech.com/forum/viewtopic ... 13&t=17038
