Motor axis direction during Auto Home Command
Which direction should each drive move during the Auto Home command? My Y drive moves the bed aft towards the Y limit switch, the X drive moves the extruter left, away from the X axis limit switch, and the Z drive moves the extruter down towards the bed.
Re: Motor axis direction during Auto Home Command
flipdave wrote:Which direction should each drive move during the Auto Home command? My Y drive moves the bed aft towards the Y limit switch, the X drive moves the extruter left, away from the X axis limit switch, and the Z drive moves the extruter down towards the bed.
all of axis should go toward their endstops.it seems that your x axis direction are reversed.you can change it's direction in the firmware.
- QQ图片20151116153019.jpg (63.24 KiB) Viewed 8065 times
Thanks Eric, where do I find that latest file for the Prusa I3 with I think it's the GT 2560 board
Never mind , I found the file!
