Page 1 of 15
How to install the firmware for GT2560
Posted: Tue Nov 24, 2015 3:19 pm
by Mark
Hi guys, recently I find some newcomers in 3D printers don't quite know how to install the firmware for GT2560 board, so today I'll show it here~~
To install the firmware, you'll gonna need Arduino 1.0.1 for old version marlin firmware (or Arduino 1.8.5 for Marlin 1.1.8), your firmware, your motherboard with a USB and that's all.
You can download the firmware for your printer here:
Let's get start for GT2560~~~~~~~~~~ 8-)
( for sanguinololu, please come to here: http://www.geeetech.com/forum/viewtopic ... 20&t=16433 )
1. Install Arduino on your PC.
If your printer is A10/A10M/A20/A20M, please use Arduino 1.8.5 to finish the upload;
If it is Prusa I3 Pro B/W/X/C, please go for Arduino 1.0.1!!
Otherwise, you might get some bugs during the verifying.
Download Arduino 1.0.1 or Arduino 1.8.5 here:
https://www.arduino.cc/en/Main/OldSoftw ... s#previous
Arduino 1.0.1.jpg (36.26 KiB) Viewed 199087 times
Arduino 1.8.5.jpg (27.86 KiB) Viewed 199087 times
2. Connect the printer to the PC with your USB cable.
3. Unzip the firmware.
Here we take firmware for I3 pro C dual extruder for example.
The process for A10/A20 series is quite similar, except the Arduino in a different version. Also, this video shows you the example:
https://www.youtube.com/watch?v=o1QKSgnk_ig
You can download the one for your printer here:
4. double click the Marlin.ino, then you'll open the whole firmware in the arduino.
5. Select proper Com port.
6. Under Tools, in Board, select Mega 2560 .
7. Finally click the arrow to compile and upload the firmware to your printer.
Part2
If your PC is MAC(OSX sierra or more high version)
1.Refer to this website at first
http://osxdaily.com/2016/09/27/allow-ap ... atekeeper/
2.Then check the flash of the mainboard,refer to:
http://www.geeetech.com/forum/viewtopic ... 974#p81974
3.Download Arduino 1.0.1
4.Other steps are same as the Windows system method
Thanks!
Re: How to install the firmware for GT2560 and sanguinololu
Posted: Mon Dec 14, 2015 10:30 pm
by mirco
Hi everybody, I can't find the firmwire for my printer it is I3 X M 201, somebody can you help me?
Thank you for your time and help!!!
Bye Bye
Posted: Tue Dec 15, 2015 3:26 pm
by Mark
Posted: Sun Jan 10, 2016 11:57 pm
by munchit1
hi, new on, but..need help please
i've got a rumba board, the one with jumpers on the motor drivers (not dip switchs) its the £50 board. i had a marlin and arduino set up that was up and running, after installing the reprap drivers and other bits the marlin editions i tried would not compile, (sorted that from this page, thank you), i know have the 'arduino mega 2560 or mega adk' in my list and the marlin now compiles..i've followed all the google methods to install to no avail, etc, and three days strait into it this as far as i've got.
...marlin now compiles, and the port shows the rumba board as 'arduino mega 2560'
my problem has been with the reprap page rumba driver (the one that enable's you to flash the board) keeps coming up with a virous, the virous is indeed listed, and it takes up to 3 reboots and 3 virous scans to get rid of the virous..some say it isnt really a virous but the majority say it is along with half a dozen diferent malware or virous programs that remove it so... not to keen on 'ignoring' that one tbh.
i did install and try that, but as soon as it was installed the pc port was no longer visable..arduino no longer picked the port up eather, nor in marlin. i've removed it.
my question, is there a page on here with relavent merlin set ups etc? and do i still need the driver now that it shows 'arduino mega 2560 or mega adk' in list?
and...which programmer needs to checked in the arduino/merlin drop down box?
am i on the right track at all??
Posted: Mon Jan 11, 2016 6:03 pm
by Mark
if you can see the com port, and can control the printer through the USB then you don't need it.
Posted: Mon Jan 11, 2016 11:44 pm
by munchit1
hmm, thank you, i'l try that shortly.
Posted: Thu Jan 14, 2016 3:58 pm
by mirco
thank you guys
Posted: Thu Jan 21, 2016 11:32 am
by jim87
hello how can i update my prusa i3x firmware to dual extruder please help thank you.
Posted: Thu Jan 21, 2016 10:53 pm
by Mark
if you have rebuild it to a dual extruder then you can use the firmware for I3 pro C.
Posted: Mon Feb 08, 2016 3:02 pm
by jim87
hi, when i set M32 code to end gcode in slic3r always get failed file, does the firmware don't recognize the M32? please help im a student, it is part of my project.
