Iduino yun shield as WiFi router and access via WAN port
Posted: Wed Nov 25, 2015 4:37 pm
by cholegm
I'm trying to configure Iduino to work as router but without success. Also, I need to access via ethernet interface (not working to).
Does somebody have a conf. example or solution how to allow access via ethernet interface and make Yun to work as router (WAN=eth, LAN=wlan)
Now is configured as (like I was find on some site):
iduino yun firewall zones configuraton
Thanks in advance and best regards,
Mladen
Re: Iduino yun shield as WiFi router and access via WAN port
Posted: Wed Sep 14, 2016 7:13 pm
by cholegm
Hello again,
I was buy Iduino Yun Shield V1.2 (exactly 3 peaces) and I using this shield width MEGA2560.
I have problems with Ethernet port. I was try to connect with multiple switches and directly to the PC but same problem, on switch is link up, on shield LAN LED is blinking but there is no connection... Shield not geting address via DHCP. When I set static IP, a can't PING or access to the Yun. Same with already configured IP address 172.31.255.254.
I was try with frimware upgrade but problem still exist.
Thanks in advance!
Best regards,
Mladen
