Autoleveling configure:
My coordinate of the probe on the manual control panel is (24, 13,1.5)
My 3D Printer is G2S with 2 hotend.
In Configuration-h I modifiy: X_PROBE_OFFSET_FROM_EXTRUDER -24 and Y -11 and Z -1.5 Is it correct?
Then I compile and I have error below.
More, with values that do not make mistakes, the printer is completely crazy. Could someone help me?
Thank's in advance.
impossible to compile after autolevel configuration
- MESSAGE ERREUR COMPIL ARDUINO.jpg (157.92 KiB) Viewed 6453 times
Re: impossible to compile after autolevel configuration
did you change any other settings? you can try to download the original firmware and compile it, see if it has the same problem.
I think I had the same problem when I made x > 19
just leave the X =-19, it won't affect the auto leveling.
